I have a Kenmore 70 series top load washer; I believe the model number is:
11022712100
The machine cycles will not advance; I have to cycle (all cycles) the load through manually. Will I need to replace the timer?
If so, does this require any special tools?
Does this require any special tricks or skills? I have worked in the construction trades for years and am reasonably adept at working with tools.
I’m having difficulty with the above model number when I browse for parts; the site doesn’t recognize this model. Do I need to add periods/dashes to the number or anything?
Thanks for your assistance,
Bill
