Brand:Kenmore
Model Number:11082872130
Main Symptom:stops after filling and agitating wont complete cycle
What happens & when: Kenmore washer fills and agitates and then stops wont rinse or spin. It makes no sounds or noises just dead stop. Then it will sporadically work threw all the cycles. I have changed the timer with two used ones and the symptoms are the same. What could be wrong?
