Kenmore 70 Series dryer timers
After a good, long while of constant, reliable use, the timer on my Kenmore 70 Series dryer stopped advancing, requiring a manual stop.
I purchased a used timer unit on another site. The part number for the original timer is 8299784, and the used unit was a 3976577 timer, which I’d read was the correct replacement part.
I replaced the timer making sure to place all wires in their correct locations, plugged it back in and fired it up. The timer advanced and all was well.
Fast-forward 24 hours to laundry day and 20 minutes into its very first Timed Dry (not auto) cycle with an actual load, it trips the breaker. (Admittedly I thought the timer caused the problem so I put the old one back in, it didn’t start, and then finally a while later thought to check the breaker. I reinstalled the used unit.)
Now this used unit will not advance, just like the original timer. The dryer still heats and works fine - it just won’t shut off on its own because the timer won’t advance. The schematic is taped inside, but I am not an engineer and A. don’t understand the schematic and B. have no measurement tools for troubleshooting.
Just a couple more bits of info: I have only ever used the Timed Dry function to test the timer. The used timer has a black wire instead of a brown wire for the timer motor.
According to the parts list for this model number, the correct part number for the timer is 8299784 and it never been changed. I did not find any proven cross references to any other part numbers including 3976577.
So the only correct timer is one with part number 8299784 which is APP AP6012590
How many different 70 series dryers are there? I can’t see the model, # anymore on this unit. But it needs a timer.
