Kenmore 665-13242K900 lights flashing
My Kenmore dishwasher, Serial # FY4603575, Model # 665-132-42K900 has the Normal Wash light blinking. I push the Cancel/Drain button and then both of those lights are blinking. I open and close the door. And the Normal Wash light resumes blinking. I’ve shut off the breaker and the same thing happens when I turn it back on. What is causing this? Thanks! Debbie
Hi.
Most likely the problem is - bad control panel. Please provide the color of the control panel for the correct part number.
