KENMORE 363 still not freezing after replacing defrost timer, heaters and thermostat
My kenmore side by side was leaking water from the ice maker in the freezer prior to the problem with it not freezing. I did the whole defrost and then replaced the recommended things . One of the heaters was bad but my freezer is no colder than it was before i replaced all this, same with the fridge. I checked to see if its defrosting and frost is still forming . The evaporator fan is blowing but not very hard. The compressor is working . I’m not sure what to try next. Any suggestions
[SIZE=“4”][COLOR=“Red”]DUPLICATE[/COLOR][/SIZE]
Please see the following
http://forum.appliancepartspros.com/refrigerator-freezer-repair/95420-kenmore-363-still-not-freezing-after-replacing-defrost-timer-heaters-thermostat.html
