Hello, I have a kenmoore elite dishwaher that will not complete a full wash cycle. The water does not appear to be heating and there is little if any steam during drying. When the machine cuts off the clean light flashes. I have done the reset with the touch pad and it did wash once or twice, but with no heating. now it flashes again and shuts off. I see that some parts stores want to sell a element kit with a control box. I found just an element here for a very fair price, but not sure what way to proceed. couls this possible be the mother board or can a bad element cause this?
[quote=WDW;690189]Hello, I have a kenmoore elite dishwaher that will not complete a full wash cycle. The water does not appear to be heating and there is little if any steam during drying. When the machine cuts off the clean light flashes. I have done the reset with the touch pad and it did wash once or twice, but with no heating. now it flashes again and shuts off. I see that some parts stores want to sell a element kit with a control box. I found just an element here for a very fair price, but not sure what way to proceed. couls this possible be the mother board or can a bad element cause this?
You may want to check the heating element and the high limit thermostat (under the tub) for continuity before ordering any parts. If both of them are good, replace the control board.
The 7 blinks of the clean LED points to the heater components failure.Unplug the dishwasher and take one wire off the part you are testing.
Using the multimeter check the heater and the hi limit thermostat for continuity. Replace the one with 0 continuity.
Both good - test the wires to the control board. Wires test OK - replace the board.
Hello all. I replaced the heating element and high end thermostat. When I turned the dishwasher over to replace the parts I found that one of the wires to the original element had burned in half. the brass fitting on the heating element has a slightly open crack in it which may have allowed a bit of water to leak throug nto the wires. After i replaced the parts the clean light was flashing so I did the test with the touch pad. At that point it through the breaker in the electricl box. Removed it again and saw no burnt wires, but no lights will come on at all at this point. Any Ideas or should I take the washer to my shooting pile out back? At least some fun.
There is a short somewhere. First check the power cord junction box. Look for any bad wires and then check the control board and thermal fuse.
Pinched wire at the bottom of the door may cause that.
Hello, Sorry to take so long to get back, but many things, heat pump, dishwasher, tv, are all breaking at the same time.
I took the machine back out and looked around at the connections, the wires, and everywhere else for burn marks or loose connections. I did not see anything so I tried it again and it ran without tripping the breaker. Perhaps a little water got where it should not have when I layed it on its side. I have washed four loads of dishes and during one of the four it quit running before the cycles were complete and the clean light was flashing again. The times it did run completey through all cycles at the end the clean light was on, but the sanitaized light was blinking.
My tap water at this faucet is 122±F and the dishwasher is not making it any hotter while runnng on heated wash or sani rinse.
Sorry to trouble you good people with this, but now I am more curious than ever.
That’s what the Owners manual says about the sanitized light: [quote]…Sanitized glows when the Sani Rinse cycle is finished. If your dishwasher did not properly sanitize your dishes, the light flashes at the end of the cycle. This can happen if the cycle is interrupted or the incoming water temperature is too low. The light turns off when you press any button or close the door…[/quote]Locate the thermistor which is attached to the bottom of the pump (look under the tub). There are the white and yellow/black wires connected to it. Check the thermistor resistance. It should read 48-52 K Ohms @ 77°F and 12-13 K Ohms @ 140°F. If the readings are wrong, replace the thermistor.
You guys are fantastic. It is refreshing to see people helping each other so much. I will dig out my old meter and check this part and get back to you.
Hello again, I just tested the thermistor. It was about 70F and the reading was 56.0 on the ohm meter. The meter was set on 200k. Thant was the only setting that read anything. Been a long while since I used one.
Any Ideas?
The thermistor looks good, but there is still a problem with the water heating. Based on your reports you did replace the heating element and the high limit thermostat. Now is the turn for the control board because this device controls the heating among other futures.
Hi Gene, I oredered the control board and it is due to arrive today. The dishwasher started working properly yesterday without me doing anything else to it. Now I will not know what the problem was. I can hold on to the new part and wait a while. What do you think?
Hi Gene, whatever made the washer work for one day stopped so I replaced the control panel and that appears to have done the job. I hve about 160.00 invested in parts, but that is much cheaper than buying a new dishwasher or calling in a repair company.
Many thanks to you and Appliance Parts Pros. All of the other sites I looked at were significantly more exspensive and did not offer the professional advice.
Hi gene, the dishwasher worked great for two days. I started it last night and woke up to clean dry dishes. Tried to use it again this evening and there is nothing. No lights at all. I tried all the reset sequences that I know with no results at all. The house breaker did not trip. Any ideas?
Check for continuity the thermal fuse which should be attached to the control board frame. If it is open, it could happen if it was improperly reinstalled from the old control board, the water inside the dishwasher was too hot or just because of its age.
Hi gene, Thanks for hanging in there. I can’t get any current through the fuse so I suppose it is bad. Did any of the parts I replaced cause higher water temperatures? I know that some sites had an element that they claimed made hotter water.
