My washer keeps blowing start capacitors, I cannot find anything else wrong with wiring or other components.
Any clues??
Any clues??
I am having trouble with your model number. Can you please check it and post again with the number.
I also cannot find info on your unit.
Did notice that you had another post about overloading the motor causing capacitor failure. I do not think this would be a factor.
The centrifugal switch should be OK. If it was sticking closed I would imagine the motor would overheat with the start winding on all the time.
I would lean towards something in the motor is causing it.
Did you check the start winding with a meter. Also did you check it to the motor’s case. Could be it is grounded.
