KA dishwasher does not fill with water
Brand:KitchenAid
Model Number:KDTM404KPS0
Main Symptom:will not fill with water. error code 9-1
What happens & when:after cycle start unit runs through drain cycle but does not proceed to fill error code stops
Error Code (if any):9-1
Parts or tests already tried:water fill valve ok. float valve replaced
With it doing this at the beginning of the cycle and the fill valve being good then the issue is with the flowmeter built into the inlet water assembly W11535094 on the left outer side of the tub.
https://www.appliancepartspros.com/whirlpool-inlet-watr-w11535094-ap7175478.html
