Brand:JennAIre Model Number:JGRP436WP01 Main Symptom: Fan not checking on and heat kicks off at 170 What happens & when: First 30-60 seconds heat kicks on and no fan. then shuts down
Error Code (if any):F8e0
Parts or tests already tried: Blower fan appears good
Also, in your help section it says you can do a diagnostic by select a 1-2-3 sequence 3 times in 8 seconds or less. That does not do anything. I have tried multiple times.
For your Jenn-Air JGRP436WP01, the F8E0 error code points to a cooling fan speed problem.
Since the oven heats for about 30–60 seconds, shuts down around 170°F, and the cooling fan doesn’t appear to start, I would focus on the cooling fan circuit before replacing any more parts.
The control board monitors the cooling fan’s operation. If it doesn’t detect the expected fan speed, it can shut down the heating system to protect the electronics.
Here’s what I’d check first
1. Check the cooling fan blades. Turn off power to the range and make sure the fan spins freely by hand. Look for anything obstructing it.
2. Inspect the fan wiring. Check the connector at the cooling fan and the wiring leading back to the control board. Look for loose connections, damaged wires, or overheated terminals.
3. Check whether the fan receives power. If you’re comfortable performing live-voltage tests, use the wiring diagram to identify the fan’s power terminals. Start a bake cycle and check whether the control supplies the specified voltage when the fan is commanded on. Be careful: this involves exposed electrical connections.
4. Check the fan speed feedback circuit. A fan can spin normally and still trigger F8E0 if the control isn’t receiving the correct speed signal. This is especially important if the fan motor has already been tested and appears good.
What the results mean
Test result
Likely problem
Correct voltage reaches fan, but it doesn’t run
Cooling fan motor
No voltage when fan should run
Control output or wiring
Fan runs but F8E0 returns
Speed feedback circuit, fan assembly, wiring, or control
Do not continue operating the oven with a cooling fan fault, and don’t bypass the fan safety monitoring.
Model-specific diagnostic test
I found a troubleshooting procedure for this model that recommends activating the Cooling Fan Low Speed through diagnostic mode, then checking the fan RPM.
The procedure identifies these electrical checks:
P8-4 to neutral: Approximately 120 VAC when low-speed fan operation is commanded.
P9-2 to neutral: Approximately 120 VAC when high-speed operation is commanded.
P3-4 to P3-5: Approximately 5 VDC for the fan speed-sensing circuit.
These are live electrical tests best performed by a qualified technician.
JustAnswer+1
Two questions before replacing anything
When you say the blower fan appears good, does it actually run during a test, or have you only checked that it spins freely by hand?
When the oven reaches 170°F and shuts down, does F8E0 appear immediately?
Those answers will help determine whether we’re dealing with a failed cooling fan, a fan speed sensor problem, or the control board not supplying power.
Thanks for clarifying. I checked the service information for your Jenn-Air JGRP436WP01, and the three-key sequence is listed for this model. However, it doesn’t necessarily mean you have to use the actual number keys 1, 2, and 3.
The instructions say to press three different keys in the same order, three times within 8 seconds.
JustAnswer+1
Here’s what I’d try:
Turn the oven off and let it cool.
Turn off the breaker for at least 30 seconds, then restore power.
Make sure the control is displaying the clock and isn’t running a cooking cycle.
Try pressing Oven Light → Kitchen Timer → Oven Light three times quickly. However, because this repeats a key, it isn’t the exact three-different-key sequence specified in the service instructions. A better choice is three separate, responsive keys on your control panel.
Watch for the diagnostic menu to appear.
If that doesn’t work, don’t keep repeating it. The problem may be the particular keys being used, the control’s operating state, or an issue with the keypad.
One question: Does your range have a touchscreen with numbers 1 through 9, or does it have separate buttons such as Oven Light, Timer, Bake, and Broil?
That will help me identify the correct buttons to use so we can get into diagnostics and test the cooling fan directly.
When you say the blower fan appears good, does it actually run during a test, or have you only checked that it spins freely by hand? Yes, spins by hand. And the Continuity test appeared to show the blower is still good.
When the oven reaches 170°F and shuts down, does F8E0 appear immediately? Yes, immediately after it shuts down the F8E0 pops on the screen.
Thanks for checking those details. That helps narrow things down quite a bit.
On your Jenn-Air JGRP436WP01, the fact that the oven heats to approximately 170°F, shuts down, and immediately displays F8E0 strongly suggests a problem with the cooling blower system.
One important detail: A blower motor can spin freely by hand and pass a continuity test but still fail to run when power is applied.
The control needs to detect proper blower operation. If it doesn’t, it can shut off the heat and display F8E0 to protect the oven.
Here’s what I’d check next
1. Listen for the cooling blower. Start a Bake cycle and listen for the blower before the oven shuts down. This is separate from the convection fan inside the oven cavity.
2. Inspect the blower wiring. Turn off the breaker and check the blower’s electrical connector and wiring for loose connections, damaged insulation, or signs of overheating.
3. Check the blower’s actual operation. Since you’ve already checked continuity and confirmed the fan spins freely, the next important step is determining whether the motor receives power when the control commands it to run.
What the results will tell us
Test result
Likely problem
Blower receives 120 VAC but doesn’t run
Faulty blower motor
Blower doesn’t receive the required voltage
Wiring or oven control issue
Blower runs but F8E0 still appears
Fan-speed sensor or feedback circuit issue
I also found service information for this model indicating that F8E0 can involve the cooling fan’s low-speed operation or its speed-feedback circuit. The diagnostic procedure includes checking the low-speed fan supply at P8-4, the high-speed supply at P9-2, and the 5 VDC feedback circuit at P3-4/P3-5. These are live electrical tests intended for qualified technicians.
JustAnswer+1
My recommendation
Before purchasing another part, let’s establish whether the blower actually operates. I wouldn’t replace the control board based on the error code alone.
One question: When you start the oven and it begins heating toward 170°F, can you hear or feel any air blowing from the cooling vent above the oven door, or is it completely quiet the entire time?
That will help determine whether we should concentrate on the blower motor itself or the circuit controlling it.
Until the fault is resolved, avoid operating the oven.
One question: When you start the oven and it begins heating toward 170°F, can you hear or feel any air blowing from the cooling vent above the oven door, or is it completely quiet the entire time? Never hear the fan starting.
The most useful information is on pages 10, 11, 14, and 15.
1. Check the cooling fan resistance
Turn off the breaker before testing. The blower motor is accessible from the rear of the oven.
According to the component testing chart:
Test points
Expected resistance
P8-4 (red wire) to neutral (white)
24 Ω ±5%
P9-2 (black wire) to neutral (white)
13 Ω ±5%
Disconnect the appropriate wiring connections before measuring resistance.
If either winding is open or significantly outside specification, the blower motor is suspect.
techsheet-w10403308-reva.pdf
2. Check the fan power and speed sensor
The manufacturer’s F8 troubleshooting procedure specifies:
Test points
Expected voltage
P8-4 to neutral, low speed commanded
120 VAC
P9-2 to neutral, high speed commanded
120 VAC
P3-4 to P3-5
5 VDC
These are live electrical measurements for qualified technicians only. The control must be commanding the appropriate fan speed when testing.
3. Determine which component needs replacing
Correct voltage but fan doesn’t run: Suspect the blower motor.
No proper fan voltage: Inspect the wiring and connections. If they’re good, suspect the oven appliance manager board.
Fan runs but the error remains: Investigate the Hall-effect speed sensor and its feedback circuit.
4. Diagnostic mode
Page 2 confirms that this oven uses three different keys pressed in sequence three times within eight seconds.
Once inside Diagnostics, select Component Activation → Cooling Fan Low Speed. The information screen displays fan RPM.
The specified ranges are 400–3000 RPM on low speed and 1000–3300 RPM on high speed.
Since the 1-2-3 sequence hasn’t worked for you, we can continue with the electrical checks rather than relying on diagnostic mode.
My recommendation
Before replacing the blower or control board, I’d start with the two resistance checks above.
One question: When you previously checked the blower for continuity, did you measure the actual resistance in ohms? If so, what readings did you get?
Those numbers will help us determine whether the blower itself has failed or whether we need to investigate its power supply. techsheet-w10403308-reva.pdf (1.9 MB)
Test points
Expected voltage
120 VAC
120 VAC
P3-4 to P3-5
5 VDC
Here are your readings:
Wire combination
Resistance
White / Black
14.1 Ω
White / Red
25.7 Ω
Red / Black
11.7 Ω
The interesting part is that 14.1 + 11.7 = 25.8 ohms, almost exactly matching your 25.7-ohm reading.
That pattern is consistent with a three-wire motor having two winding sections connected through a common terminal.
What this tells us:
Your blower motor windings don’t appear to be open. We also don’t see an obvious direct short between the wires. However, these readings alone don’t prove the motor is good or confirm that it’s receiving power.
Since the blower never starts, we need to determine whether the motor is receiving the proper voltage.
Reconnect the blower motor wiring.
Start a Bake cycle and monitor whether the blower attempts to run.
If you’re comfortable performing live-voltage tests, check the blower supply using the wiring diagram to identify the correct terminals and expected voltage. Be careful—this involves potentially lethal voltage.
If the correct voltage is present but the blower doesn’t run, suspect the blower motor.
If voltage is missing when the control should be operating the blower, investigate the wiring and blower control circuit.
I wouldn’t replace the blower motor based on these resistance readings alone.
One important question
Were these three resistance readings taken directly at the blower motor with its wiring harness disconnected?
That will help me interpret the readings correctly and narrow down whether we’re dealing with the blower motor or its control circuit.
FAILURE (Leftmost 2 Clock Digits) ERROR (Rightmost 2 Clock Digits) LIKELY FAILURE CONDITION F8 E0 Low fan speed underspeed E1 Low fan speed overspeed E2 High fan speed underspeed E3 High fan speed overspeed MESSAGE: The product is experiencing a problem and can no longer be used. SUGGESTED CORRECTIVE ACTION PROCEDURE PROCEDURE: To enter the Diagnostics Mode, press three different keys in sequence three times in a row within 8 seconds. When in Diagnostic Mode, press ERROR DIAGNOSTIC to verify the error codes. 1. Unplug range or disconnect power. 2. Wait for at least 30 seconds. 3. Plug in range or reconnect power. 4. Enter Diagnostics and navigate to the Component Activation list. 5. Turn on the Cooling Fan Low Speed. 6. Navigate to the “More Information” screen. 7. Navigate to the “Information” screen (Screen 5). Information shown (Screen 5): Plat1A Upper Plat2 Upper Cavity Upper Meat Probe Upper Plat1B Upper Target Upper Fan RPM Right: READ FAN SPEED. High Speed 1000 - 3300, Low Speed 400 - 3000. 8. Check for proper voltage input at P9-2 and neutral for high speed fan, P8-4 and neutral for low speed fan when cooling fan should be running by completing following steps. 9. Unplug range or disconnect power. 10. Connect voltage measurement equipment. 11. Plug in range or reconnect power. Measure voltage and confirm voltage reading is 120V. If it is not, unplug range or disconnect power and go to Step 15. If it is, go to Step 12. 12. Check for proper voltage input at P3-4 and P3-5 and confirm voltage reading is 5VDC. If it is not, unplug range or disconnect power and go to Step 15. If it is, go to Step 13. 13. Unplug range or disconnect power. 14. Replace cooling fan. Go to Step 17. 15. Check integrity of all harness wires and connections between the oven appliance manager and the cooling fan. Ensure no shorted wires to chassis. If the wiring is pinched or damaged, replace the cooling fan harness. Go to Step 17. If the wiring is good, go to Step 16. 16. Replace oven appliance manager. Go to Step 17. 17. Replace all parts and panels before operating. 18. Plug in range or reconnect power. 19. Enter into diagnostics mode and verify that fan speed is running within range. (High speed: 1000-3300, Low speed: 400-3000) Once Fan Speed is completed, navigate back to the activation list and activate the Cooling Fan High Speed and return to
Access the wiring carefully so you can back-probe the connector.
Start a Bake cycle and monitor the voltage supplied to the blower motor when the control calls for cooling.
Important: This is a live-voltage test. Only attempt it if you’re comfortable working around energized electrical components. We also need to confirm the correct motor terminals and expected voltage from the wiring diagram before testing.
If the motor receives the correct voltage but doesn’t run, that points toward a faulty blower motor. If the voltage is missing, we’ll need to trace the power supply back toward the control circuit.
The oven heats to approximately 170°F before shutting down.
The F8E0 error appears immediately.
The cooling blower never starts.
The blower motor turns freely by hand.
Your resistance readings suggest the motor windings aren’t open.
You’re not getting voltage at the blower motor harness.
At this point, I wouldn’t replace the blower motor. We need to determine why it isn’t receiving power.
The next step is to check the blower motor’s power supply circuit. A failed control board, damaged wiring, or a problem with the blower control circuit could prevent the motor from running.
Keep in mind that the control may not energize the blower immediately when Bake starts. We need to verify voltage when the blower is actually being commanded on.
If the wiring diagram confirms the motor should be receiving voltage but none is present, we’ll need to trace that circuit back toward the oven control.
One question: When you checked for voltage at the blower motor harness, did you leave the oven heating until it reached approximately 170°F and displayed F8E0, or did you check immediately after starting Bake?
That will help us determine whether the control is failing to send power or whether the blower simply hasn’t been commanded on yet.
You’re going to have to check the wiring back to the circuit board under the burner top behind the oven lock.
if the wiring is good you will need to check for power at the connections on the board either with the connections unplugged or by back probing the connections
Blower motor low
speed
Rear P8-4 (R) to
Neutral (W)
24 ± 5% 120V Motor running
Blower motor high
speed
Rear P9-2 (BK) to
Neutral (W)
13 ± 5% 120V Motor running techsheet-w10403308-reva.pdf (1.9 MB)
Had it connected from when it started heating to when F8E0 was on the display (when I said immediately, it takes about 5 seconds for the error message to come on the screen after the heat shuts down).
