JennAir range wiring
We bought a house with an S156 range.
We found the owner/builder used non-code wiring in many places. The stove was not working well, and we found a 50 amp breaker with 8/2 AWG w/ground (no neutral).
We need to know what wire to use and what plug/socket to replace on the stove.
The run from the box is about 45 feet.
We disconnected it, so we have no cooking.
Thanks.
[quote=km8am;313997]We bought a house with an S156 range.
Thanks.[/quote]
KM,
We no longer have or supply that type of information,
There are too many separate, individual, city county, state, wiring and building codes
But,
Based on your description, the only things I would change :
Replace the wiring with 8/3 awg or 8/4awg(L1,L2, N,and grnd wires)
(you’d need to remove the grounding strap from the range terminal block)
Then order the corresponding 50 amp outlet and 50 amp range cord.
You should contact a local electrician, and have him give you the building specs / codes, to be safe.
Good Luck,
:cool: :cool: :cool:
