I was rudely awakened last night by incessant “beeping” of my rangetop.
I showed the “Fault Code” F1-8. I would appreciate some assistance in diagnosing what the problem might be. Also a readable wiring diagram would be of assistance.
Appliance - Jennair Rangetop/Oven
Model # - JGS8850ADS
Serial # 16900361GC
Approx 5 years old
Your error indicates a stuck key.
Usually this is the key pad but can be the control board.
The only way to confirm it is to use a meter and test the keys on the keypad (see the tech sheet).
Sometimes disconnecting/reconnecting and cleaning the ribbon cable (see below) will solve this but it usually it only works for open keys not shorted keys, so is a long shot
Unplug the unit
Open it up
Clean the edge connector.
