Jennair Range Controls
Some of the panel buttons work and some don’t for my oven. Should I replace the control board AP4508101 or is it a push button problem?
Replacement parts for JES9900BAS models | AppliancePartsPros.com
The tech sheet may help.
This is a bit of a crap shoot as they do not give the pin-out/wiring for the keypad so it really cannot be checked.
Have you tried unplugging the unit to see if it will reset.
Perhaps try cleaning the keyboard to control panel connection.
Be sure to unplug the unit when dong this.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
16027004.pdf (1.1 MB)
