Jennair Microwave/Oven Combo
Brand: Jennair
Model Number: JMW2430DS03
Main Symptom: No Op
What happens & when: Always
Error Code (if any): F2E1
Parts or tests already tried: Powered Down for 10 minutes to no avail
I ordered/purchased part #W11236896 (AP6333319) from APPros today. It should be delivered tomorrow. Before I try to install it, please confirm for me that it will work. I know it is not a stainless steel overlay. That is ok, I just want to know it will be functional in our unit.
Hello Tjleonard59, with the error code F2E1 indicating a stuck or shorted keypad, replacing the console panel would be the corrective step if there was not a loose wire connection. However, the two that I am seeing for this model are different part numbers. The following links can be used to view the console panels that are showing with this model number.
Black overlay console panel- W11299401 Wall Oven Microwave Combo Control Panel Console | Genuine Whirlpool OEM In Stock
Stainless overlay console panel- W10887855 Control Panel | Genuine Whirlpool OEM In Stock
