I need a fan switch for a Jennair C301. I can’t seem to find this part anywhere. Can anyone suggest an alternative–maybe changing the entire control panel or something. I don’t want to replace the entire cooktop because then I would have to change the countertop opening etc.
I would take the switch to an electronics supply house you should be able to get a switch that will work. Be sure to get the same or better voltage and current ratings.
Also the size of the actuator and the mounting hole locations.
