Cook top and grill work. Oven will heat to 300 but no further.
I assume the element works since it heats at all, is there a thermostat or some other sensor that decides when to regulate current to element? Is there a control board that serves this purpose?
A model number would help.
Find your model number - AppliancePartsPros.com
[COLOR=“Blue”]assume the element works since it heats at all, [/COLOR]
On many units they switch back and forth between the bake and the broil elements so maybe one element is no good.
[COLOR=“Blue”]is there a thermostat or some other sensor that decides when to regulate current to element?[/COLOR]
Yes there is an oven sensor. It is a tube that extends into the oven top/back.
It shuld measure about 1100 ohms at room temperature.
[COLOR=“Blue”] Is there a control board that serves this purpose?[/COLOR]
Cannot say some units do and others do not.
