Jenn-Air
I have a Jenn-Air dish washer that is not pumping water through the sprayers. I have checked to see that nothing is clogged and I can hear the inpeller spinning when the machine is on but it sounds like it slows way down as the presure builds and isn’t turning fast enough to push water up the sprayers. Any ideas?
Disassemble the pump to access the chopper and seals (#8 & #9 on the diagram) and inspect all parts. Follow the disassembly instructions in the Service manual.
Here are the breakdown diagrams and Replacement parts for JENN-AIR JDB4000AWW Dishwasher - Undercounter | AppliancePartsPros.com
