Jenn-air w130 oven replace door hinge
The door on my oven doesn’t close tightly, and I thought perhaps the hinges could be the issue. I found the replacement part number, but I’m wondering if there is anywhere to find how to perform the replacment.
I’ve seen how some ovens are very easy to replace the hinge, as the hinge is part of the door, and when lifted off, it’s easy to access. On this model, the hinge is part of the oven “frame” so I will have to remove pieces/parts of the oven, but I’m not sure which parts.
Any help would be appreciated!
Thank you for the reply.
The once I remove the door, the hinge remains attached to the oven (not the door). The springs are not visible (they are inside the oven “frame” somewhere).
I tried finding a service manual that might give a better idea on dis-assembly, but have been unsuccessful.
