Jenn-Air Oven (JJW9130DDB)
The right-most buttons have stopped responding (3, 6, 9 and oven light). The rest of the touch pad is working normally.
I’m trying to find out if I should order a new Control Panel, or a new Control Clock (the electronics behind the panel) they are both they same price - about $150 (each). I am told that I cannot return them once I get them.
Any advice?
You may not have to order any parts.
You will notice that all the keys you mentioned use track 10 on the ribbon cable as a common, could be this connection is just dirty.
RIBBON CABLE CLEANING
Unplug the unit
Open it up
Clean the edge connector.
Could also check it with a meter.
Check from track 10 to other no good key tracks as it may be a crack on the ribbon cable that you cannot see or on the actual keypad itself
If no good then it is a keypad problem.
If OK then it could be the control board
Odds are high that this is a keypad/connection problem.
I have the exact same issue on jenn air jjw8130dds
I followed your instructions and removed the ribbon cable and cleaned it. I reseated the cable and have the same issue. The 3, 6, 9, and oven light are not working.
Also wondering the same question, what part to replace?
Where do I want to validate with the meter? I know you mentioned trace 10, but I am not sure how to validate that. I assume you are suggesting doing a continuity test across the ribbon, but I can not see where / how to validate that.
THANK YOU!! This worked for me! The two top rows of the numeric keypad were not responding, but cleaning the ribbon cable connection fixed it.
I initially checked all the connections and even swapped out the control board with a spare. I figured it was probably either the ribbon cable or the keypad as the problem remained after the swap.
I then pulled the ribbon cable and cleaned its connectors and those on the control board with 99% alcohol. Powered it up…and it worked!
[quote=denman;127636]
Unplug the unit
Open it up
.[/quote]
