Jenn Air slide in gas range keeps shutting off
Everything works fine until you want to bake something in the oven. It starts fine and begins heating up, then it shuts off. You can turn it on again, and it starts up again then a couple of minutes later it shuts off again, same thing over and over again. I pulled the temp sensor and it ohmed out at 1090 so its not that. Is it the computer control board? The control panel has been replaced before and works fine every button works. We have shut the breaker off to reset the oven, to no avail.
Please help
When the oven stops, does it stop heating or turn off totally at the control, like the bake cycle has been canceled?
It shuts off at the control panel like the bake cycle is cancelled
Does it always do it in the same amount of time? I am suspicious of the cancel key on the touch pad and wonder if it may be shorting.
No it was intermittent, and got progressively worse over the course of 2 weeks now it shuts off after a couple of minutes. The touch panel was replaced about 2 years ago and seems to work fine. We shut down the power for 24 hours and upon powering up it showed codes ee214 m214, then they cleared.
Those are manufacturing codes and irrelevant. I suspect the cancel key may be shorting. Turn the breaker off to the range and use a hair dryer to heat that key until very warm while rubbing over it very firmly many times. Then, see if the behavior changes. Let me know what happens.
Hi Tom,
Same trouble, same range…did the fix work for you?
Dan
