Jenn-Air replacement cartridge compatibility
Brand:Jenn-Air
Model Number:c222, serial # 568046XG
Main Symptom:
What happens & when: The cooktop is functioning OK but I am wanting to know if I can replace the original grill cartridge that came with the cooktop with part # 87904A (coil burner cartridge). Can you please tell me if the cooktop and the coil burner cartridge are compatible? Thank you.
Yes, the 87904A should be the correct cartridge for your unit.
Thanks for the quick reply!
