I have a Jenn-air refrid/freezer which is showing frozen water on the sides & back at the inside of the freezer. I also noticed that the water is coming from the top where the lights are located and forming ice cycles as it dripps. Any advice Thanks Jerry
Jerry,
Sounds like one or both ice maker water valve solenoids (main and secondary water valves) are not closing properly. It’s very hard to diagnose exactly which one is bad (possible both are) and I would recommend to replace both water valves.
Here is the Service manual.
Here are the breakdown diagrams and Ice maker replacement parts for JENN-AIR JS48CSFXDA Ref - Sxs | AppliancePartsPros.com
