The right front burner cook top light stayed on for over 12 hours before going off. Burner works fine and light is off. Could this be caused by a spill or is something on the way out?
Parts for Jenn-Air JES9800AAW Range - AppliancePartsPros.com
See the attachment for the wiring diagram
As you can see the lights are controlled by the infinite switches so probably he one for that element has a problem.
A spill may have caused it. If you had a spill and the unit is now working correctly I would not worry about it.
JES9800.pdf (823.5 KB)
