Jenn - air radiant cooktop
I would like to now how to install a replacement element part#74010156 for a Jenn-Air Radiant Cooktop.
Thank you,
Walter
[COLOR=“Red”][SIZE=“4”]DUPLICATE[/SIZE][/COLOR]
Please see the following
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/256932-cooktop.html
that link is old and doesn’t work
booger
I do not know what link you are talking about.
If you mean the link in this post then I tried it and it works for me.
If you mean the links in the post that this post points to then the second link in that post does work. At least it works for me.
[quote]
[COLOR=#000000][LEFT][COLOR=#000000]denman booger[/COLOR]
[LEFT][COLOR=#000000]I do not know what link you are talking about.[/COLOR]
[COLOR=#000000]If you mean the link in this post then I tried it and it works for me.[/COLOR]
http://forum.appliancepartspros.com/...epartspros.com[COLOR=#000000]If you mean the links in the post that this post points to then the second link in that post does work. At least it works for me. Read more: [/COLOR][/LEFT]
Read more: http://forum.appliancepartspros.com/newreply.php?do=postreply&t=257599#ixzz1QeQiqIoa
http://forum.appliancepartspros.com [/COLOR]
[/LEFT]
[/quote][LEFT][COLOR=#000000][LEFT][COLOR=#000000][COLOR=#000000]Yes I must of just tried the first one. Data File Host which stated The file you requested (id 258ef303) does not exist. It might have been deleted due to inactivity (no downloads) or due to not complying with our terms. But indeed you are right the second one works Download JEC0530.pdf with JECO530 Downloaded 3 times File: JECO530.pdf Size: 3.09 MB.. You are all over it denman. Thanks as I had the same problem! You guys really are great and appreciated. Booger JEC0530[/COLOR][/COLOR][/LEFT]
[COLOR=#000000]
[LEFT]Read more: http://forum.appliancepartspros.com/newreply.php?do=postreply&t=257599#ixzz1QeQu6txp
http://forum.appliancepartspros.com [/COLOR][/LEFT]
[/COLOR]
[/LEFT]
