The oven works fine and the buttons all work, however the display panel does not work to show time or temp. Do I need a whole new control panel or just replace the clock assy panel?![]()
Replacement parts for JENN-AIR SVD48600W | AppliancePartsPros.com
You need Item 3 in Section 4 Electronic Oven Control.
Our Jenn-Air model W142 lost all illuminated windows and clock; appears to operate normal. What needs to be checked/replaced?![]()
BobBetty
Please start your own post using POST NEW TOPIC.
Adding to another persons post when your Model Number is different will just confuse things.
PS: Does sound like your control board/timer needs replacing.
Thanks in advance
denman
