Jenn-Air microwave lightbulb burned out
The lightbulb (lamp) in the Jenn-Air microwave model JMC8130DDS needs to be replaced. How do I get to the bulb?
You will need to disconnect the power, pull the unit out from the wall and then remove the top panel. The bulb ([COLOR=#0066cc]AP3038375[/COLOR]) will be on the right side. You may need to remove an inner panel to get to it. Not to difficult, just a lot of screws.
