Hello:
I have a Jenn Air JDB8200AWP1 Dishwasher which is not activating the heating element so no hot water and no heated drying at the end of the cycle.
In addition the “Precision Dry” button on the touch Panel does not illuminate, although it does beep when pressed.
I Ohm checked the heating element and the thermostat and both checked out.
So now thinking it is either the control board and/or the touch panel. Is there any way to determine which of those should be replaced?
I also ran the Service Diagnostic Cycle. At the end of the cycle the board beeps once for roughly 2 seconds continuously then turns off and no lights are illuminated on the touch panel.
Any advice would be appreciated.
Scott
