Jenn air gas range control problem
Have a jenn-air dual fuel drop in that won’t turn off the electric broil element. Prior to this, error codes f2 and f3 displayed. Key pad seems functional other than fact that can’t turn off broiler.
Parts for Jenn-Air JGS8750ADS Range - AppliancePartsPros.com
See the attachment for a wiring diagram. It is for a JGS8750C but should be close if not the same as yours.
Sounds like the control board is toast either the broil element control relay’s contacts are welded together or the electronics is keeping the relay energized.
The F2 error is usually an over temperature error which would make sense as the broil element is always on.
JGS8750.pdf (130.5 KB)
