Jenn-Air Gas Cooktop Doesn't Stop Sparking When Switching off
Model CVGX2423
Expressions Sealed Gas Downdraft Cooktop
Hi Expert,
I’ve problems with one of the burners often used: when switching off the burner using knob, the sparks and clicks would not stop. And the light on the knob is till on. Initially, I thought it was because the switch was not shut off completely. It turned out that that the switch is fine. Also, I replaced that switch with a less used one but the problems persist. Right now I had to shut off the gas line to avoid major accident.
Could you please share some knowledge and experience on what should be done to get this fixed?
Thanks greatly in advance!
Yi
Probably a bad valve switch.
Hi Sir,
A development about the incidence: Right now, when switching on the knob of that burner. All I can hear is clicks ans sparks but absolutely no fire on that burner is on.
Another indicator: other burners work as normal.
Any new ideas about the cause of the problems?
