Jenn Air Fridge Side not cooling
Main problem.
Ice forms at the inlet of the styrofoam duct that leads from freezer compartmrnt into the refrigerator section. This area is covered by a plastic cover that has some frost/ice in it. The stuff in the styrofoam duct is definitely hard ice, not frost. It took me about 15 minutes with a hair dryer to melt the ice in the duct. After I melt the ice, the unit will work for several weeks, but then the ice builds up again. There is also some ice on the refrigerator wall near the crisper - the side next to the freezer.
There is no ice on the coils in the freezer and the freezer is working OK. Fan is running OK
What should I check? What is the most likely cause?
Hi.
Check the refrigerator door gasket for air leaks.
Here are the breakdown diagrams and Replacement parts for Jenn-Air JSD2789GES REF - SXS/I&W | AppliancePartsPros.com
Thank you.
Simon.
