Recently had a burn out on my fountain touch pad. Both the control board and touch pad, along with the wire harnesses and any plastic next the units melted. Prior to the burnout, the light would not go out, everything seemed to work fine except the light.
I replaced everything I thought needed to be replaced, such as the cnrtl-elec (AP4068351), CNTRL Board (AP4068159), limit switch (AP4069438), light socket, wire harnesses (AP61003458) (AP61004775), Ice door Fountain Kit (AP4068333), insulation, etc. Its a plug and play senario, very easy to install. After installation, I noticed everything worked fine except the cubed ice, half the time it dispensed crushed. The light, lock, water and crushed buttons worked great. I was okay with half cubed… Been installed for approx. 5 days and…
Until last night about 4pm, the water came on by itself, made a mess on the floor and we could not shut it off until we opened the freezer door. Now nothing works in the touch pad, except the light stays constantly on.
I need my refrig back, any suggestions whether the new cntrl board, touch pad or limit switch went out? What would have caused the new issue?
DG
