Jenn Air F1 Error Code
I began getting an F1 error and constant beeping on my upper oven while it was cooling down. The ERC (clock) was relatively new so I ordered and replaced the touchpad. Now the upper oven does not work at all, even when I put the old touchpad back in. Any suggestions?
you need to check the oven sensor, if the oven sensor is open or shorted that is it. but if good needs relay board (parts are made in mexico, asia or ???)
It was the relay board - Thanks for the help!
No problem.
