Hello. My stove has been flashing an error code F1-7 for several weeks. I just performed the test on this site where I disconnected the green ribbon that comes from the keypad to the electronic control, and then turned the power back on. I immediately got the F1-7 code and beeping again. Can someone tell me what exactly this means? My local repair shop is saying that I need to replace both the touchpad AND the electronic control. Does this sound reasonable?
Parts for Jenn-Air JES9750AAB Range - AppliancePartsPros.com
I doubt you need both.
F1-7 is a disconnected keypad so is difficult to troubleshoot as they do not tell us which track/connections they monitor to determine if the keaypad is disconnected.
I would try the following first.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
Also check the tracks in the ribbon cable from the keypad/control panel to the control board. A magnifying glass comes in handy here.
You could also use a meter to check the keypad as per the tech sheet. If it checks out OK then I would replace the control board first. Still a bit of a crap shoot but your odds are better.
If you cannot check the keypad then I would replace that first again it is a crap shoot.
JES9750.pdf (951.1 KB)
