Jenn Air Double Oven Beeping
repalced ERC clock control and still beeps after a while. service agent says needs new control board but noine available from amnufacturer. Reade I may be able to buy a new board through ([COLOR=#0066cc]www.************************.com[/COLOR]). any suggestions or is it time for a new oven?
John:confused:
Control panel replacement parts for JENN-AIR WW30430B Walloven - S/c Ele | AppliancePartsPros.com
Here is a manual. It covers a number of different units so be careful that the section you use applies to your unit.
http://www.servicematters.com/maytag_library/docs/16010312.pdf
Strange that you do not get an error code.
By “control board” I am assuming you mean the keypad.
Try running diagnostics.
Try the following
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
I would not put additional dollars into the un it unless you have good reason to believe that the part you are purchasing is going to fix the problem.
