My dishwasher is making a loud grinding (metal) sound when it starts washing. Sounds like something in the disposal part. (maybe?) I cannot find any information on checking for debris stuck in it. Do I need a repair person?
The model number you posted does not come up. Verify and repost it please.
The model number is JOB 4000 AWB.
Sorry for the delay. Remove the lower spray arm, the filter plate (#4 on the diagram) and the discharge housing (#5). Check the wash impeller. If there is nothing wrong then remove the impeller and the accumulator (#7) and check the chopper and its shaft.
Here are the breakdown diagrams and Replacement parts for JENN-AIR JDB4000AWB | AppliancePartsPros.com
I’m looking for the handle part of the Latch Assembly which you have a diagram of here: Whirlpool W10130695 Dishwasher Door Latch Assembly - AppliancePartsPros.com
My door latch is fine, it’s just that the tabs of the handle have broken off, and now I can no longer latch/unlatch my dishwasher door.
I know that the handle comes as part of the assembly, but I’d rather not spend $25 on the entire assembly, when all I need is the handle itself.
If you could tell me the part number and the cost for the handle alone, I would appreciate it.
Thanks!
