I recently order a Panel-con (6K2104 part no. WPL 6-919765), order Number 926634, for a Jenn-Air dishwasher. I’ve removed the screws holding the old panel except for 2 Fastener panel screws (part no. AP4365077) that may require a special tool to remove and install. If you look at the Panel-Con it has at the top two large opening which it looks like a 90 degree pliers is needed to access the screws. I’m not sure, please advise…:mad:
Perhaps this will help
http://www.servicematters.com/maytag_library/docs/16022783.pdf
So, Can you tell me what is the solution to remove the control Panel? Same problem/challenge
Bruce
