One of the lights under a knob of this cooktop is not longer illuminating, however the corresponding ‘hot surface’ light still works.
I’m wondering what replacement part(s) I need to get the light under the knob (which illumates the numbers / level of heat) to work. In case the part is specific to the knob itself, the one not working is the light below the upper-left knob, the ‘double-element’ burner.
TIA for any assistance,
Jan[/quote]
Jan,
Does the burner work correctly ?
If so, you’ll need to order and replace the light box.
