[FONT=Times New Roman][SIZE=3][COLOR=#000000][/COLOR][/SIZE][/FONT]
[SIZE=3][COLOR=#000000][FONT=Calibri]I have model SVD48600w JenAire (JA) range. [/FONT][/COLOR][/SIZE]
[FONT=Times New Roman][SIZE=3][COLOR=#000000][/COLOR][/SIZE][/FONT][SIZE=3][COLOR=#000000][FONT=Calibri]All of the burners work fine.[/FONT][/COLOR][/SIZE]
[FONT=Calibri][SIZE=3][COLOR=#000000]The oven will not heat. When I go to the oven settings, whether on conventional or on convection bake the elements do not comeon at all. They are cold to the touch.[/COLOR][/SIZE][/FONT]
[SIZE=3][COLOR=#000000][FONT=Calibri]The broiler function works fine, and the fan will run insidethe oven when on broil. Therefore I do not think it is the elements. [/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Calibri]When I run the broiler, and then switch the range controlsover to bake, the oven will register a temp increase (as shown on the panel),but I do not know if the temp registered is correct.[/FONT][/COLOR][/SIZE]
[FONT=Calibri][SIZE=3][COLOR=#000000]The clock display went (many months ago), but the ovencontinued to work. Then the oven quit.[/COLOR][/SIZE][/FONT]
[SIZE=3][COLOR=#000000][FONT=Calibri]I replaced the dim clock board with a new one, but the ovenstill will not heat.[/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Calibri]Any help is appreciated.[/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Calibri]Thanks Very Much[/FONT][/COLOR][/SIZE]
Hi.
Using the multimeter check across the bake element contacts for 240VAC with the control set for BAKE.
If there is proper voltage - replace the bake element.
If you don’t get 240VAC then you should replace the relay board.
Here are the breakdown diagrams and Body parts for Jenn-Air SVD48600W - AppliancePartsPros.com
Post the results.
Simon.
