dryer wont heat,check all the themostate and thermel cut off and also thermel fuse.it tumble but it did not heat,i diagnosed the 110 which come from motor is coming but other 110 is missing which come from some where control system,what could be wrong
Here is the tech sheet
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%203980052.pdf
[COLOR=Blue]
i diagnosed the 110 which come from motor is coming but other 110 is missing which come from some where control system,what could be wrong[/COLOR]
Check that you have the proper power at the plug.
L1 to Neutral and L2 to Neutral should be 120 volts
Also L1 to L2 should be 240 volts.
It is not uncommon to loose half the line without actually tripping the breaker.
Depending on which side drops out the unit will run but not heat.
Flip the breaker off/on slowly a couple times.
Be careful, 240 volts is lethal.
thank u for your response,there is no problem with power ,L1 and L2 already giving me 240
[COLOR=Blue]dryer wont heat,check all the themostate and thermel cut off and also thermel fuse[/COLOR]
Is the heater itself OK?
Looks like the heater relay and the motor relay are the same.
Check this just to be sure.
If they are the same, swap them
Now if it will not start you know the relay is shot.
yes i am thinking aswell this could be the heater relay but not a control board which is beside the relay? thank you for your quick response
Could be the control board but you want to eliminate everything else before coming to that conclusion as it is the most expensive part.
