Brand: Frigidaire
Model Number: FGHD2433KF0
Main Symptom: Functionality
What happens & when: Some buttons work and some don’t when trying to start a cycle.
Error Code (if any): None
Parts or tests already tried: AP6327227
It’s a compound issue that I’m fighting.
First of all the latch switch contactors had broke and stopped working so I purchased a new latch/switch and installed. Immediately about 50% of the time the display would indicate to close the door. Confirmed by testing with a multi meter that the switch was functioning correctly. Switch fixed it.
Second issue. Shortly after while running a cycle the washer would just shut off. No codes or display, and could start it right back up….sometimes it would finish, sometimes not. So I ordered a new board after reading my symptoms and their fixes, installed and no buttons worked. I power cycled the washer and it would only let me select quick clean. So I left it alone out of frustration, then returned hours later and pressed the normal wash button and it lit up…weird. Started the cycle and it went all the way through no issues.
*Interesting note/observation: With the original board the normal wash would start at 99+ mins and finish after an hour and a half. With this new board normal wash starts at 33 mins and finishes in 33 mins.
So my question is… A- did I get the right board? If not B- Can I get some assistance figuring this out?
