Is this part faulty?
[SIZE=3][COLOR=#000000][FONT=Times New Roman]Hi[/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Times New Roman]I have the above listed dryer. It has decided not to work today. If you set it to a programme and press start and nothing – it just sits there.[/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Times New Roman]I was advised that it might be an open thermostat.[/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Times New Roman]After examining the dryer thermostats (after turning off the power, checking for live feed and ensuring on one could turn the supply on) by removing the front panel, I’ve got the following results:[/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Times New Roman]Two thermostats on the heater box: both appear to be closed circuit (have continuity)[/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Times New Roman]There are two thermostats on the dryer exhaust ducting:[/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Times New Roman]One is a straight in line one and that appears to be closed.(thermal fuse???)[/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Times New Roman]The other one is round and has four connectors on it. Two thicker wires (from heater?? And this part appears to be ok. The other part (inner and thinner wires) appears to be open circuit. (I think it had heater or something similar on it???)… written on it it was part number 3387137. Now my question is, is this party faulty[/FONT][/COLOR][/SIZE][FONT=Times New Roman][SIZE=3][COLOR=#000000] ???[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Also, if it is faulty, where can I get one? I’ve not manged to find any suppliers in the UK so far.[/COLOR][/SIZE][/FONT]
:slight_smile:
First question…Did you disconnect the wires from each of the thermostats prior to doing the continuity check?
2nd ?.. Did you check to make sure you have full power to the plug in?
You should be able to get any of the parts needed from this site.
Nat
