Hi gang,
I have a Frigidaire Dishwasher that all of sudden stopped working. The front panel (all solid state, no dials) lights up, but when I start it no water starts going in. I hear something switching like normal, just no water. I replaced the water inlet valve, but no change. I am not sure if the valve is bad or I am doing something wrong.
I turned off the power, removed the wire plug from the valve, and put multimeter probes on each post. My meter reads 0L. I got a new one, tested it and it says 0L before installing it. I installed it anyway, and same thing.
Am I doing something wrong?
FWIW:
The float switch is ok. It moves up and down freely. I checked the posts with my meter while the float is down and it beeps. I lift it up and the meter goes quiet.
I have a clamp meter but am not sure what wires to check for AC, or even if I am using the clamp right (I know to only put the clamp around one wire at a time haha).
I took the front panel off and the wires all appear in good shape. Too sets of Black&White wires go up to the latch. A bundle of wires go to the display/control panel.
I filled the tub up with water, and was able to get it to drain by pushing the CANCEL button.
Thanks for the help!!!
