Internal schematic for interlock switch asm
Where can I get a diagram of the interior of GE part #WD21X10169?
Thanks.
Should be in the pack under the dishwasher, If its not there, please explain the problem your having,:slight_smile: and we may be able to help.
D/W had stopped mid-cycle twice over three day period … keypad dead, too. Came back to life once for a while, but has stayed dead after second malfunction. First tried replacing interlock switch with new from AppliancePartPros … no change in status. Just replaced with new (free) control module assembly from GE (under the wire before warranty expires) … unit still dead. Wondering if I could have reversed the position of the two internal switches in the interlock switch assembly when I replaced it … they look identical but have slightly different numbers on them … and if that could be an issue. It still may be something else, but I don’t know which way to go.
Thanks … that’s why I ask about a schematic.
Wow, Thats a tough one, After looking at the parts manual, I really don’t see anything else it could be??? Do you have a way to check for power at the board? I find it hard to believe that the door switch isn’t just a plug in part. Carefully check the connection to the HOUSE wiring!!! Thats all I can think of!!!:slight_smile:
