I did search for posts about intermittent heat, but all I found was one for no heat (for Estate dryers). If I simply missed a relevant post, I apologize for double-posting, and please direct me to the post. Otherwise…
This could be Model #EED4100WQ. Couldn’t quite make it out when I was upstairs and didn’t have my glasses. Sorry. I can get it if needed, but they seem pretty much the same.
So, there is intermittent heat. My mother normally uses/used a certain cycle and sometimes the clothes dry fine, and sometimes they don’t dry and she says they don’t even feel warm. I always use a different cycle and hadn’t noticed a problem. She switched to using yet another cycle and didn’t have a problem…until today. When one load dried and one didn’t, and the one that didn’t apparently didn’t have any heat. So the problem could be getting worse.
I read about what to do/check, and here’s what we know:
The dryer vent was cleaned out–from the outside of the house, we went in with a vacuum and cleaned it out. There did not appear to be any build-up, though. We haven’t cleaned the hose at the back of the dryer (yet) but because there was no build-up, and we can feel plenty of air coming out when operating, it doesn’t seem likely that that part is clogged and causing the problem. (Also, it’s intermittent.)
Circuit Breaker/s – doesn’t seem likely, as it runs okay (1 breaker, I guess) and the “no heat” is intermittent, so the 2nd breaker must be fine.
Yes, it’s in a closet. But this is a recent issue and, again, it’s intermittent, so being in a closet must be fine/it must have enough ventilation/space.
So it’s down to a thermostat, a fuse within the dryer (?), a heating element (there may be more than one?), a thermal limiter (no idea what this is), or a burnt wire. There has been no burning smells, so it doesn’t seem likely it’s the last one.
Of the other possibilities, which could cause an intermittent problem?? Or is it something else that I haven’t been able to come up with?
Related questions –
I’m pretty sure my dad has an Ohmmeter, but does it have to be a certain kind? I haven’t fully read that post about testing for continuity, but I will. Although first I need to know where those parts are and how to get to them.
Of those possibilities (of what could be wrong), do you (APP) carry the part/s?
Is it something that I could replace/repair on my own?
3b) If so, where can I find a schematic/diagram to guide me?
Thank you for any help provided!
