I have a GE GTDP200GM0WW Electric Dryer, I need to replace the backsplash/control panel.
Does anyone know if I can use the backsplash panel from a GE DBXR463ED2WW?
The panels look so similar & I can get one for cheap I’m just no sure if it’s compatible. Any help would be greatly appreciated, thanks so much.
I do not think it will work.
The units use different timers/knobs.
Also DBXR463ED2WW uses a timer support plate behind the control panel and your unit does not.
On top of that they use different end plates.
