I have purchased a switch kit and connector receptical for my Jenn-air cooktop from Appliance Parts Pros. Unfortunately, there are no wiring diagrams that come with the parts. 2 questions: both wires from the connector receptical are red in color - one has a small paper tag with technical information. Does it matter WHICH of the recepters in the switch these are connected to on the switch (H1 or H2)? Also, I want to verify which cooktop “power source” wires go to the switch. Looking at the back of the switch (“TOP” up): top left, marked “P” goes to the light indicator; next, marked “L1” goes to the black wire from source; top middle, marked “L2” goes to the red wire from source.
What is the part number of the part(s) you purchased?
AP4009015 (12001676) Terminal block kit, ceramic
AP4087111 (700855K) Switch kit
[LEFT][COLOR=#000000][quote]…both wires from the connector receptacle are red in color - one has a small paper tag with technical information. Does it matter WHICH of the recepters in the switch these are connected to on the switch (H1 or H2)?..[/quote][/COLOR]
[COLOR=#000000]No, it does not make any difference.[/COLOR]
[/LEFT]
[LEFT][COLOR=#000000][quote]…I want to verify which cooktop “power source” wires go to the switch…[/quote][/COLOR]
[COLOR=#000000]The best help (without presence of the wiring diagram) is to follow the old switch connections. If this particular switch has been already disconnected, check out any other switch connections.[/COLOR][/LEFT]
[LEFT][COLOR=#000000]Gene.[/COLOR][/LEFT]
[quote=Gene;234699]What is the part number of the part(s) you purchased?
Gene.[/quoTE
PART NUMBER 318293827
[quote=SHARON BROWN;663764][quote=Gene;234699]What is the part number of the part(s) you purchased?
Gene.[/quoTE
Hi Sharon,
Can you be more detailed please?
THE ORIGNIAL SWITH WAS 310369613 REPLACED BY 318293827 NO DIAGRAM WAS SENT WITH THE NEW SWITCH. hOW DO I GET A DIAGRAM FOR THE PROPER WAY TO WIRE THE NEW SWITCH?
What is the complete model number of the unit?
Model # Frigidare 318183506:)
The Number For The Cooktop Is Feg32c44ac The Other One Was For The Switch Place Panel Sorry:(
Sharon,
This is not a valid model number.
SERIAL #NF70621467 THIS IS A COOKTOP
This model number (Feg32c44ac) does not come up. The closest model number I found is FEGB24S5ASE. Verify and repost it please. The Model Number Locator can help you.
