I removed my heating element to have it tested. I had to replace the heating element and the thermostat and thermal cut units were good. The problem is, I did not mark which wires of the harness go to which parts. So i need to know which wires go to which part and which side of each part.
Since the circuit is AC it does not matter which side the wires go to as long as they are wired in the correct order to complete the circuit.
GEW9200.pdf (334.3 KB)
