I see there are many agitator drives here where the dogs have become brittle with age and broken. I have ordered the repair kit for this model, and I have disassembled the agitator assembly. Before removing the bolt and all the remaining broken pieces of the dogs, I noticed the mover agit moves up and down considerably, even far enough for the catch gear on the inside of the mover agit to clear the dogs. I noticed when I further disassembled that the washer AP3094463 is worn very thin. Will installation of the kit correct the up and down play or do I also have another worn part in need of replacement?
Once you install the dogs and put the 7/16" bolt back in place it should be fine, but if not let us know.
I installed the kit and it works great now, thanks sidfink43
