For Bosch SHE55M12UC/64, replacing the front control fascia/panel and the switches/buttons is fairly straightforward once you know how the fascia releases.
Turn the breaker OFF or unplug the dishwasher. You will be working directly around the control and switch wiring.
Open the dishwasher door completely.
Look across the inside top edge of the door. Remove the four screws securing the upper fascia/control panel. You normally do not need to remove all the screws running down both sides of the inner door.
Close or partially close the door so you can support the control panel from the front.
The fascia is still retained by two molded plastic locking tabs/prongs that snap into the metal portion of the door. Gently work the fascia forward at those locations. Don’t simply yank it—the old plastic can be brittle.
Switches and buttons
Once the fascia is loose, take a picture before removing anything.
The plastic buttons/keys fit into rocker-type positions in the fascia and operate the actual electrical switches behind them. The replacement 00665886 fascia does not come with the buttons, so the existing buttons must be transferred unless you’re replacing them as well.
For the electrical switches:
00424410 — On/Off main switch, diagram position 0102
00187205 — switch assembly, diagram position 0104
00422169 — push-button set, diagram position 0108
00665886 — fascia/control panel, diagram position 0107
Disconnect the switch wiring one connector at a time. I recommend moving each connector directly from the old switch to the corresponding terminal on the new switch rather than disconnecting everything at once.
Installing the new fascia
Transfer the buttons/keys into the new fascia first. Make sure each one pivots freely and returns normally—you don’t want to assemble the door and then discover a button is binding.
Install the switches into their respective holders and reconnect the wiring.
Line up the two fascia locking tabs with the grooves in the metal door, then press the fascia into place until the tabs engage. Reinstall the four upper screws from inside the door.
Restore power and check every button before running a cycle.
Pro tip: Don’t overtighten those fascia screws. On an older Bosch like this, the plastic mounting points can crack surprisingly easily. Snug is enough.
