Installed new control board, dials now flipped 180 degrees
Brand: Frigidaire
Model Number:FEFB9200ES0
Main Symptom: Dials flipped
What happens & when: After replacing control board 134523200NH, dials flipped 180 degrees. Took apart and flipped dial 180 degree (6 turns), but still didn’t work.
Parts or tests already tried: 134523200NH
From what I can find, there should be a small tab on the knob pin with a notch on the opposite side that goes into the control. It should line up with a notch and tab in the potentiometer in the control. Is the tab missing from the pin? Here is an example of the tab and notch.
The pin does have it, I took the whole thing apart again and was able to get everything to work correctly. For anyone looking to do this, it’s very finicky, take your time with it and it may take a few tries. My dryer is back to working correctly!
