I was looking for information on how disconnect the two halves of a split air conditioning unit without losing any freon. I’m not sure if the manual I have explains the installation since it is in español but I’m looking for general information for all mfgs.
Basically, the airco comes with the inside and outside halves separated and capped with the full freon charge in the condenser. During installation the copper tubing is connected between the halves and the unit is bled to remove air using the compressor of the unit and a set of airco gauges.
It is also possible to “suck” all the freon back into the condenser/compressor leaving the evaporator dry. This is used for disassembling the unit for moving or for cleaning the inside unit.
Does anyone have detailed instructions on how to separate the units without losing freon and to reinstall them? I have gauges and have recharged units before but have never worked on a split unit.
[quote=95yj;81755]I was looking for information on how disconnect the two halves of a split air conditioning unit without losing any freon. I’m not sure if the manual I have explains the installation since it is in español but I’m looking for general information for all mfgs.
Thanks much.[/quote] You say you have gauges and have recharged before ? Not for nothing but there is a lot of misinformation in your post. Just what are your exact qualifications ? If you do not mind me asking.
Obviously I am not an HVAC technician or I would not be asking these questions. I have fixed leaks in auto airco and recharged and I have also added freon to home units that were low and freezing up.
As far as what I’m capable of, I’m a network systems engineer, have worked as an auto mechanic, have remodeled my own homes, added additions, done major plumbing work, have rewired my own homes and replace electrical service panels (which by the way passed code from an inspector) so I am plenty capable. I fully understand how airco works although I haven’t done much in the way of service.
My original post is based on seeing what others have done. I live on a small island and unlike living where there are a multitude of HVAC professionals, there’s not a whole lot of difference between the skill level of the service engineer who comes out and overcharges you for simple maintenance and the average Joe with a decent aptitude for hands on. (This is by no means meant to be a slam on a qualified trained professional, but we don’t have the luxury of having many of them down here and usually who you wind up with is someone who just barely knows what they are doing.)
So, set me straight; that’s why I’m asking questions.
I’m sorry; the previous post was not meant to be negative in any way. You asked a question and I answered. That’s the problem with email, postings, memos, etc. There’s no tone of voice. I just reread my posting and could see how as a whole it could be taken incorrectly. I also understand the CMA. I apologize for any misconception.
I notice on the web site in your signature that you have books available. Which would you recommend for the homeowner doing their own maintenance? I don’t need to pass any tests or anything. I would just like to increase my knowledge level. Pretty much the only airco down here are split units (except for some businesses) since we only cool the room we are currently in at the time.
Attach the gauge manifold to the high and low side charging ports on the condensing unit.
Remove the caps to gain access to the service valves. You will need allen wrenches to turn them as they are recessed.
Run the unit and gradually close down the high side service valve, while watching the low side, gradually close the low side until guage starts to lower. DO NOT bring into a vacuum. @ 2psi., shut electric disconnect and shut low service valve.
Kewl, that’s the info I was looking for. Thanks much.
What about reassembling the unit after disconnecting the lines? What’s the best way to bleed the air out of the lines when hooking the inside and outside unit back together?
Hi there have u gotten ur answer to how to reinstall the unit, if so can u please post it or sent it to me on mak13666@gmail.com it will be much appreciated
[QUOTE=95yj;81755]I was looking for information on how disconnect the two halves of a split air conditioning unit without losing any freon. I’m not sure if the manual I have explains the installation since it is in español but I’m looking for general information for all mfgs.
Hi there, i was just looking for the same answer, can u please let me know hot to reinstall the unit, the info about the removal was as clear as water, thanks
umm i think i would call a local contracter to reinstall unit for you there is qwite a few things that you can mess up including the compressor and you just lost more money than your trying to save
